Hope you can find this test file for testing fw_serializers
useful.
Hi, thanks for the pointer.
I am playing with this for days now.
Funny pat is that I have my own dill implemetaion of moving py objects across network but I am in ocean of fireworks code trying to mimic the right solution. This might help when I get back to pycharm.
Hi @sashak. Hope this example of TestSerializer could help.
You can compare the way you define/init your MyTaskObject
For pymongo>=4.0.0 issues, something we came across is AttributeError like
‘Cursor’ object has no attribute ‘count()’
So if you are debugging your class with those errors, please do check the pymongo 4.0 changes.
If you want to PR something later when you finish debugging, please create a new branch other than main
and then submit the PR. We have a standard review and merge process with timely responses for those valued PRs.
Thanks for your efforts.
Hi, pymongo was not an issue for me.
I am running pymongo4.0.1 against
mongodb-org-shell-5.0.5-1.el8.x86_64
mongodb-org-server-5.0.5-1.el8.x86_64
Serialization and deserialization via FW did not work for me.
What did work is following
I am converting nested object to nested dicts via my own method.
Then custom dict is passed to fireworks custom task,
All of thi is done with my own wrappers to FW
e.g.
workFlowObjects = list()
mpacObj = self.myDict(self.mpacTask)
mpacTask = MPACWFTask(serviceDriver= mpacObj)
workFlowObjects.append(Firework(mpacTask))
# ## store workflow
# ##change the port from str to int
self.mpacTask.clusterObj.lpad.port = int(self.mpacTask.clusterObj.lpad.port)
fire = LpadMpac(workFlowObjects, self.mpacTask.clusterObj.lpad)
# ## init mongo DB queue
try:
launhcpad = fire.setupLP(reset=True, needPasswd=True)
except Exception as clusterErr:
print(clusterErr)
# ## load workflows
fire.setup()
on the other end (remote)
passed = fire.singleShoot()
will invoke
Custom FireTask
def run_task(self, fw_spec):
mpacTaskObj = type(‘mpacTaskObj’, (object,), self[‘serviceDriver’])
print(mpacTaskObj.mObject)
print(self._fw_name) # print the name of the Fireworker
return FWAction()
This is all good, one more thing is that I need to expand on the nested dict to nested objects and not just inital layer of dicts.
All in all it works now for me.
I will in Feb look into serialization again and possibly fix things if they need to be fixed.
Unit test do work, so most likely ether I am not composing object correctly through my app thus repr is not present or otherwise I am not using FireTask documentation correctly …
Thanks all for help…
PyTask will be forked and merged this weekend …
Hi @sashak
This has likely been addressed but Fireworks is indeed supported. We are currently having some issues with Pymongo 4.0 right now (due to a merge I committed, I admit ). See this PR here Pymongo 4 Fixes (WIP) by ardunn · Pull Request #473 · materialsproject/fireworks · GitHub where I aim to fix pymongo 4.0 compatibility issues, but it is likely due to upstream problems with the mongo source code and it should only affect fws tests, not many real uses of fws (to my knowledge).
