Thanks again.
However, my problem is not resolved quite yet…
After I create the fws, I try to manually add them to a Workflow before adding that to the launchpad:
wf
= Workflow([fw1, fw2, fw3, fw4, fw5], {fw1:fw2, fw2:fw3, fw3:fw4, fw4:fw5},
name=“single stochastic workflow”)
Hence why I need the unique ids now. I tried hard-coding fw_id in the yaml, but it didn’t take. Where should that go in the yaml? Is there a better way to do this?
Dan
On Friday, September 8, 2017 at 12:45:46 PM UTC-6, ajain wrote:
Negative ids will be reassigned when entered into the launchpad so dont worry about it
If you really want to set ids yourself add a fw_id key in your YAML but suggest that you use negative ids. Follow tutorials for examples this should already be documented
On Fri, Sep 8, 2017 at 11:34 AM Daniel Shaw [email protected] wrote:
This is a follow-on to the previous question I had today. I’m creating 5 fireworks from five different files. I’d like them to come back with unique IDs, but they all come back -1 (the call is Firework.from_file(filename)).
Is it possible to have these fireworks have different ids? How?
Dan
You received this message because you are subscribed to the Google Groups “fireworkflows” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To post to this group, send email to [email protected].
Visit this group at https://groups.google.com/group/fireworkflows.
To view this discussion on the web visit https://groups.google.com/d/msgid/fireworkflows/d69783db-f182-450d-b575-0b8cac47108e%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Anubhav
