Fitfc: limited number of perturbation?
Dear Dr. van de Walle
I’m using fitfc to calculate vibrational properties and it generates 190 perturbations in total. VASP relaxations for these perturbations show no problem. The postprocessing (step 4 in your instruction: fitfc -f -fr) however returns ‘nan’ in the ‘svib_ht’ file and an empty ‘vdos.out’.
If I delete most of the perturbations but leave the first 60 (from index +/- 0 to +/- 29), I got a non-empty ‘vdos.out’ file with frequencies in it.
I wonder if there is a limited number of perturbation that fitfc could handle? Could you please help?
Many thanks,
Thien
There is no fixed limit of perturbation. Dropping some perturbations is probably not a real solution (you must have many zero frequencies now).
I suspect the issue is that the equation matrix is ill-conditioned (hard to invert) and that causes numerical problems. You can try
  1. reduce the -fr=… option (i.e. fit fewer springs)
  2. try the -cs option (this removes nearly colinear lines in the eqn matrix, but is quite slow) This was the default in versions before 3.15
  3. try a better linear algebra solver. As of version 3.15 you can use lapack. Uncomment the lines
    #LDLIBS=-lm -lgomp -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core
    #CXXFLAGS=$(PATCHCXXFLAGS) -O3 -DATATUSELAPACK
    in the atat/src/makefile and comment the lines staring with LDLIBS and CXXFLAGS
    (you may need to edit the libs for your system)
    This will also be a lot faster when you get it to compile on your system.
thank you for your answer~ :smiley:
Hello
Rencently I was learn to use the fitfc. but when i use it no matter I use the composite or the pure metal. i only got one perturbation file in each strained volumes files. I enlarged the er number, there is still no change. Can you help me and tell me how did you got he 29 paertrbation files? Ionly have the +/- 0 .
Thank you very much!
Yasmina
FYI, for a pure element, it is often the case that only on perturbation is generated - this is a consequence of the high symmetry of the system.
