FITFC: Upper range of -ms
Is there an upper range that the -ms tag can be set to when using the fitfc command?
Real materials typically only expand by a few percent before melting, so that should give you a guidance on what to select. The default is -ms=0.01 . I would not go beyond 0.09 . Do remember that this is a volumetric expansion (not a linear expansion).
