I am trying to run LAMMPS using fix_adapt applied to the pair eam/fs. However, I have obtained the following returning:
ERROR: Fix adapt pair style param not supported (../fix_adapt.cpp:309)
As much as I understood, the message says this specific parameter is not programmed into the corresponding pair style. However, the Lammps documentations show the opposite (http://lammps.sandia.gov/doc/fix_adapt.html).
Can anyone appoint what have I done wrong? My input is below.
fix_adapt.html).
you don't say which LAMMPS version you are using. the online documentation
always refers to the latest patch version of LAMMPS and thus may document
features, that don't exist in older versions of LAMMPS.
