Hi Guys,
I need some help. I want to use fix adapt with some GPU pair styles, for example, lj/cut/gpu. I had read the manual and found that it is possible to add a “scale” variable with extract method to the pair*.cpp.
My question is: Is it difficult to add this method in GPU potentials? Is it necessary to add to both lj/cut and lj/cut/gpu or some other file? I was looking for some GPU potential with this method but I haven’t found in LAMMPS.
Best Regards,
Rodolfo.
