fix atom/swap
Deal all,
I am using fix atom/swap command, but I get different results when I run the same script with different versions. When I used the lammps-22Aug18 , I think the results were reasonable. But when I used the lammps-7Aug19, most of the Pb atoms were replaced by Al atoms, there is same problem??
Any help would be appreciated.
Hongtao Liang
my input script:
atom_style atomic
lattice fcc 4.9095
region YYr1 block 0.0 10.0 0.0 10.0 0.0 10.0 units lattice
create_box 2 YYr1
create_atoms 2 region YYr1
pair_style eam/alloy
pair_coeff * * AlPb.eam.alloy Al Pb
neighbor 2.0 bin
atom_modify sort 0 0.0
thermo 1000
thermo_style custom step temp pe etotal press vol pxx pyy pzz enthalpy lx xlo xhi ly ylo yhi lz zlo zhi
thermo_modify flush yes line one
compute YYc1 all pe/atom
variable YYv0 equal etotal
variable YYv1 equal vol
variable YYv2 equal lx
variable YYv3 equal ly
variable YYv4 equal lz
fix YYo1 all ave/time 1 1000 1000 c_thermo_temp v_YYv0 v_YYv1 v_YYv2 v_YYv3 v_YYv4 file 06.Ave
timestep 0.001
velocity all create 1000.0 12345 dist gaussian mom yes rot yes
fix YYMD00 all momentum 1 linear 1 1 1
dump dump1 all custom 1000 04.Trajectory.xyz id type x y z
fix YYMD all npt temp 1000.0 750.0 0.1 iso 1.0 1.0 1.0
run 100000
unfix YYMD
fix YYMD all nvt temp 750.0 750.0 0.1 #iso 1.0 1.0 1.0
fix YYMD1 all atom/swap 1 1 2223456 750 ke yes semi-grand yes types 1 2 mu 1.70 0.00
run 500000
Deal all,
there was a sign error in the mu parameter that was corrected after the 22 August 2018 release.
please see the backward compatibility note for version 10 October 2018 at https://lammps.sandia.gov/bug2018.html
and https://github.com/lammps/lammps/pull/1143 for more details.
