fix bond/create with force or stress or shear threshold instead of Rmin?
I am using the command fix bond/create for simulating solid formation. For the moment, I only can use the distance Rmin. Is there a way to generate bond creation with other parameters (for instance: force or stress or shear threshold )?
Thanks in advance for your help
Regards
ARIANE
Only if you add code to fix_bond_create.cpp for those conditions.
