fix/bond create
I would like to further add to the previous comments on fix bond/create .
“One solution to this problem is to force the fix bond/create to re-count the bonds at each” - Pierre de Buyl
Although this can be achieved by modifying the source file, the easiest would be to populate dummy bond types (with same bond coeffs) in a data file and by using fix bond/create in a loop where the bond type changes at every iteration. This way at every iteration the number of bonds of bond type an atom I can have can be manipulated.
I am not sure if this helps.
Arun
