fix bond create the cut off is 7.6 but your pairwise cutoff is 1.12 ?
“Rmin must be <= the pairwise cutoff distance between itype and jtype atoms, as defined by the pair_style command”
fix bond/create creates bonds based on the neighbour list which depends on the pairwise cutoff
I am not sure whether the fix bond/create is creating bonds in your case.
Arun
