fix bond/swap command
Syntax:
fix ID group-ID bond/swap fraction cutoff seed
ID, group-ID are documented in fix command bond/swap = style name of this fix command Nevery = attempt bond swapping every this many steps
- fraction = fraction of group atoms to consider for swapping
- cutoff = distance at which swapping will be considered (distance units)
- seed = random # seed (positive integer)
Examples:
fix 1 all bond/swap 50 0.5 1.3 598934
Nevery did not show on the command line...
There should be 7 args in this fix,
The C++ code "narg != 6" will lead to a illegal fix.
FixBondSwap::FixBondSwap(LAMMPS *lmp, int narg, char **arg) : Fix(lmp, narg, arg) { if (narg != 6) error->all(FLERR,"Illegal fix bond/swap command");
