Hi Steve,
I am trying to extend the ‘fix bond/swap’ command to the polymers with dihedral terms and no special bonds (special_bond 0 0 0). Here I attached my revised version on the ‘fix bond/swap’ (I call it ‘fix bond/swapall’ instead). It works well if I only use 1 CPU. However, when I run the simulation with 8 CPUs (1 node), there are always errors like below:
PBS: End PBS Prologue Tue Aug 30 18:17:42 CDT 2011 1314746262
[qnode0624:18099] *** Process received signal ***
[qnode0624:18099] Signal: Segmentation fault (11)
[qnode0624:18099] Signal code: Address not mapped (1)
[qnode0624:18099] Failing at address: 0x15f5e2d0
[qnode0624:18099] [ 0] /lib64/libpthread.so.0 [0x2ac2e0a2c4c0]
[qnode0624:18099] [ 1] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZN9LAMMPS_NS13DihedralTable6singleEiiiii+0x2c6) [0x4e1d66]
[qnode0624:18099] [ 2] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZN9LAMMPS_NS14FixBondSwapall12dihedral_engEiiiii+0x29) [0x535ef9]
[qnode0624:18099] [ 3] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZN9LAMMPS_NS14FixBondSwapall12pre_neighborEv+0x2724) [0x533e14]
[qnode0624:18099] [ 4] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZN9LAMMPS_NS6Modify12pre_neighborEv+0x3f) [0x5f30af]
[qnode0624:18099] [ 5] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZN9LAMMPS_NS6Verlet3runEi+0x1f3) [0x712323]
[qnode0624:18099] [ 6] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZN9LAMMPS_NS3Run7commandEiPPc+0xb93) [0x6e8ed3]
[qnode0624:18099] [ 7] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZN9LAMMPS_NS5Input15execute_commandEv+0x27a3) [0x5cccd3]
[qnode0624:18099] [ 8] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZN9LAMMPS_NS5Input4fileEv+0x2e8) [0x5c9e38]
[qnode0624:18099] [ 9] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(main+0xad) [0x5dbfbd]
[qnode0624:18099] [10] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2ac2e0c56974]
[qnode0624:18099] [11] /hpc/home/yli791/lammps-5Apr11revised/src/lmp_quest(_ZNSt8ios_base4InitD1Ev+0x41) [0x45f5f9]
[qnode0624:18099] *** End of error message ***
fix_bond_swapall.cpp (42 KB)
fix_bond_swapall.h (1.53 KB)
