I’m using fix deposit to add atoms to a surface (wall/region surface), I found that after some steps, the temperature suddenly increases wildly from 300 K to more than 10000 K. No special operations between the two output steps. Does anyone have some ideas about this?
I attached a part of the log file and the input script:
Step CPU all_comt TotEng PotEng KinEng
520000 1107.9676 291.76786 -473.194 -548.63734 75.443335
522000 1122.0002 300.80863 -472.80752 -551.10175 78.294226
524000 1135.9185 297.39284 -474.82871 -552.54099 77.712276
526000 1149.7769 292.14102 -481.64981 -558.30706 76.657251
528000 1163.6012 304.01443 -485.56969 -565.73973 80.170043
530000 1178.7277 10792.857 224272.72 -599.41768 224872.13
532000 1198.0074 9736.5589 406839.83 -635.48005 407475.31
534000 1215.9096 10152.683 572681.6 -643.40895 573325
536000 1233.5887 10839.76 786197.92 -649.99146 786847.91
538000 1250.9888 11613.607 1067282.2 -653.95743 1067936.2
540000 1268.413 12365.14 1413949.6 -657.56018 1414607.2
542000 1285.9298 13069.8 1763506.4 -660.99865 1764167.4
544000 1303.4609 13821.006 2170217.6 -656.50805 2170874.2
546000 1320.943 14590.982 2647370.7 -656.55402 2648027.3
ERROR on proc 3: Particle on or inside surface of region used in fix wall/region (…/fix_wall_region.cpp:238)
compute all_comtemp all temp/com
compute_modify
all_comtemp dynamic yes extra 0
fix 1 all nvt temp 300.0 300.0 0.5
fix_modify 1 temp all_comtemp
fix
addwater all deposit 30000 1 200 2015 region slab near 3.0 vz -3.0 -3.0 units box
Wei Xiong
I'm using fix deposit to add atoms to a surface (wall/region surface), I
have you visualized the trajectory? does the temperature increase
correlate with the impact of a water molecule?
what is the assigned initial velocity of your water molecule (regard
the units setting!), what is your time step?
have you tried a shorter time step? or a slower initial velocity of
the deposited molecule? or both?
Axel, yes, I have tried smaller timestep from 5 fs to 1 fs, and smaller velocity from 30 to 3 A/ps. The same problem happens.
As you can see from my attached video (https://db.tt/oSi0GAnv), atoms seems suddenly being “freezed” at a certain step (during the process of fix deposit), the corresponding temperature increases fast from 300 K to 100000 K. Do you know what will be the problem?
I’ve attached the complete input script and the thermo output file.
input file:
processors 2 2 1
atom_style full
pair_style sw
read_data data.10
neigh_modify every 1 delay 0
pair_coeff * * mW.sw mW
region 0 block 1.0 319.32 1.0 319.32 -10.0 0.0 units box side out
fix wall0 all wall/region 0 lj93 {epsilon}e-3 2.5 20.0*
*fix_modify wall0 energy yes*
*region 1 cylinder z 11.44 11.44 5.0 0.1 50.0 units box side out*
*fix wall1 all wall/region 1 lj93 {epsilon}e-3 2.5 20.0
fix_modify wall1 energy yes
compute all_comtemp all temp/partial 1 1 0
compute_modify all_comtemp dynamic yes extra 0
velocity all create 300.0 2014 rot yes dist gaussian
dump 2 all custom 2000 all.lammpstrj id x y z
dump_modify 2 flush yes
timestep 1.0e-3
fix addwater all deposit 20000 1 1000 2015 region slab near 3.0 vz -3.0 -3.0 units box
run 20000000
output file:
Step CPU all_comt TotEng PotEng KinEng Atoms
1430000 5236.2265 300.96256 -421.54838 -504.41674 82.86836 2030
1432000 5250.003 287.46894 -427.26726 -506.13097 78.863703 2032
1434000 5263.8396 302.91931 -423.72964 -506.53196 82.802315 2034
1436000 5277.1322 276.11525 -430.36503 -508.22718 77.86215 2036
1438000 5290.7144 289.89165 -428.71642 -508.90894 80.19252 2038
1440000 5304.0082 297.43659 -425.68669 -508.00274 82.316052 2040
1442000 5317.2449 294.43989 -429.3541 -510.37237 81.018268 2042
1444000 5330.2976 310.32766 -425.2395 -509.54134 84.301843 2044
1446000 5343.4225 493.01668 -398.0041 -515.33698 117.33288 2046
1448000 5357.0297 12144.115 1595.1303 -599.39828 2194.5286 2048
1450000 5371.002 21611.905 3293.1247 -608.664 3901.7887 2050
1452000 5385.2051 34750.058 5662.7718 -608.90745 6271.6792 2052
1454000 5399.5096 46631.01 7809.4875 -611.24441 8420.7319 2054
1456000 5413.6446 63146.407 10795.191 -613.48363 11408.675 2056
1458000 5427.877 83882.26 14539.005 -615.62632 15154.631 2058
1460000 5442.2068 101770.03 17771.023 -618.99532 18390.018 2060
