Hi
Is this command( fix deposit) applicable to a cylindrical substrate? I did not notice anything about this in the guide. I encounter errors when using this command for cylinder substrate
Hi
I don’t see how the geometry of the substrate should have an impact. Those errors have likely a different origin.
error:“fix deposit region doesnot support a bounding box”
for:
group car type 5
region cc cylinder z 15.50 15.50 17.00 INF INF side out units box
fix coat car deposit 1000 5 1000 29494 region cc near 1.0
or
group car type 5
region cc block -5.00 30.00 -1.00 30.00 INF INF side out units box
I do not know in which part I have made a mistake that I encounter these errors
please guide me…
From the fix deposit
documentation:
The fix deposit
command must use the region
keyword to define an insertion volume. The specified region must have been previously defined with a region command. It must be defined with side = in.
Thank you very much .It was solved.
