fix evaporate: Bond atom missing in image check (../domain.cpp:765)
I need to delete water molecules within a specific region every now and then during my simulation.
Maybe I misunderstood fix evaporate, I’m using it like that:
fix 7 all evaporate 100 1 delreg 49892 molecule yes
and Lammps complains about it in the very 1st step with
"Bond atom missing in image check "
I thought the “molecule yes” keyword should prevent this kind of errors.
Any hints?
BTW: I use the lammps version from March 31th,2017
Another detail: my atomic id’s or not consecutive. Might this be the reason?
I think I found the ‘BUG’ :
Using full periodic boundaries (ppp) everything’s fine. But when I change the boudnaries to say fpp, fix evaporate doesn’t work.
Is there a way to handle this?
best regards,
frank.
