I am simulating a system with two species (Liquid Water- Platinum). It looks something like attached image. I want to write a fix as follows:
It compares the magnitude of the Interaction forces, between Water and Platinum and between Water and Water molecules. and checks for Force(water-platinum) > Force(water-water) where-ever applicable.
For doing this, I believe I need to use the subroutine, pair_lj_cut. Could any of you please confirm if this would indeed be the right approach to solving this problem?
a custom fix style doesn't seem like the right approach for this. a
compute style
1. It compares the magnitude of the Interaction forces, between Water and
how is "magnitude of interaction forces" defined? how can you compare
water-platinum to water-water forces? why not simply look at the
interaction energy?
there is no such subroutine in LAMMPS. the right approach would be writing
a compute style. you may want to look into compute group/group, compute
pe/tally or compute force/tally.
Dr. Plimpton, your reply helps but I intend to use that comparison between forces and write a fix for temperature scaling for the atoms which satisfy the condition of Interaction Potential (Water-Platinum)> Interaction Potential (Water-Water). If I dump the snapshots of the system, will I be able to implement my temperature scaling when the force loop runs each time using another fix?
Dr. Kohlmeyer, if I use a group command, I guess I will only get the group interaction potentials and not per atom interaction potential?
using another fix?
of course not. when you use re-run, the trajectory will not change. the
purpose of rerun is to analyze a previous run.
don't guess. that is a very bad habit in science. your description of
what you want is quite confusing and you have not provided any additional
explanation or answered my questions.
