When two separate molecule commands were used
molecule ch4 mol.ch4.txt # 1st molecule command
thanks for reporting. this is indeed a bug in fix gcmc.
the following change to fix gcmc should make it work:
diff --git a/src/MC/fix_gcmc.cpp b/src/MC/fix_gcmc.cpp
index e0a269b…fbe6b6b 100644
— a/src/MC/fix_gcmc.cpp
+++ b/src/MC/fix_gcmc.cpp
@@ -501,7 +501,7 @@ void FixGCMC::init()
if (ifix < 0) error->all(FLERR,“Fix gcmc rigid fix does not exist”);
fixrigid = modify->fix[ifix];
int tmp;
// FixRigidSmall::set_molecule stores rigid body attributes
// FixShake::set_molecule stores shake info for molecule
According to the changes suggested by Axel, I changed the src/MC/fix_gcmc.cpp in lammps-stable-31Mar2017 at these places:
(1) @@ -501,7 +501,7 @@ void FixGCMC::init()
//if (onemols != (Molecule **) fixrigid->extract(“onemol”,tmp))
if (&onemols[imol] != (Molecule **) fixrigid->extract(“onemol”,tmp))
(2) @@ -516,7 +516,7 @@ void FixGCMC::init()
//if (onemols != (Molecule **) fixshake->extract(“onemol”,tmp))
if (&onemols[imol] != (Molecule **) fixshake->extract(“onemol”,tmp))
(3) @@ -1397,12 +1397,13 @@ void FixGCMC::attempt_molecule_insertion()
// if (rigidflag)
// fixrigid->set_molecule(nlocalprev,maxtag_all,imol,com_coord,vnew,quat);
// else if (shakeflag)
// fixshake->set_molecule(nlocalprev,maxtag_all,imol,com_coord,vnew,quat);
for (int submol = 0; submol < nmol; ++submol)
if (rigidflag)
fixrigid->set_molecule(nlocalprev,maxtag_all,submol,com_coord,vnew,quat);
else if (shakeflag)
fixshake->set_molecule(nlocalprev,maxtag_all,submol,com_coord,vnew,quat);
(4) @@ -2058,11 +2059,12 @@ void FixGCMC::attempt_molecule_insertion_full()
// if (rigidflag)
for (int submol = 0; submol < nmol; ++submol) {
if (rigidflag)
else if (shakeflag)
And then recompiled the LAMMPS executable:
$make clean-all
$make mpi
However, this error ”Fix gcmc and fix shake not using same molecule template ID” still occurs when I’m trying to use two separate molecule command with fix gcmc.
src/MC/fix_gcmc.cpp in * lammps-stable-31Mar2017* at
these places:
$make clean-all
you are missing a command here:
make package-update
which will update the copy of fix_gcmc.cpp that will be compiled.
$make mpi
yes, because you compiled the unmodified installed version of the file.
Based on Axel’s suggestion, I changed the src/MC/fix_gcmc.cpp and recompiled the LAMMPS.
Now, the new executable lammps works fine and the bug “Fix gcmc and fix shake not using same molecule template ID” is eliminated! Thanks to Axel Kohlmeyer!
Now I arranged the recompiling process (version: lammps-stable-31Mar2017) as the following procedures :
Change the src/MC/fix_gcmc.cpp file as suggested by Axel at : https://sourceforge.net/p/lammps/mailman/message/35868292/
(attention should be paid, that one should not make a backup of the fix_gcmc.cpp file or other “extra cpp files” in this src/MC directory, otherwise the compiling process would engage an error when the compiler detected extra cpp files! At first, I made this mistake by backup the fix_gcmc.cpp and the compiler gives me error until I removed this backup file.)
Clean the object files:
$make clean-all
Update the MC package after changes in the fix_gcmc.cpp
$make package-update
Build the executable:
$make mpi
