I use lammps to study the friction behavior between a tip and a four-layer graphene substrate. The topmost layers of the tip are treated as rigid. The bottommost layer of the substrate is fixed. To control the temperature of the system, fix langevin is applied to three atomic layers in the middle of the tip and one atomic layer in the middle of the substrate. The damp factor in fix langevin command is 0.05ps. The timestep of the simulation is 0.0005ps. A constant normal force and a constant sliding velocity Vx=10 m/s are applied to the rigid layer of the tip. Then I have the following questions:
- The damp factor in fix langevin command is appropriate?
2.When I use the following command to control the temperature, I found the mean force in x direction of the tip is larger than that of the substrate. I think langevin thermostat lead to such results. Which command did other people use to eliminate its effects?
boundary p p s
compute Ttipm tipm temp
compute Tgram1 gram1 temp
compute 1 gra property/atom fx fy fz
compute 1x gra reduce sum c_1[1]
compute 1y gra reduce sum c_1[2]
compute 1z gra reduce sum c_1[3]
compute 6 tip property/atom fx fy fz
compute 6x tip reduce sum c_6[1]
compute 6y tip reduce sum c_6[2]
compute 6z tip reduce sum c_6[3]
fix 3 gram1 langevin 300.0 300.0 0.05 68954256 zero yes
fix 4 tipm langevin 300.0 300.0 0.05 68954256 zero yes
fix_modify 3 temp Tgram1
fix_modify 4 temp Ttipm
- When I use commands as follows,I found the force in the x-direction of the tip and the substrate is a pair of interacting forces. Is the result appropriate?
compute Ttipm tipm temp/com
compute Tgram1 gram1 temp/com
Step Temp 1x 1y 1z 6x 6y 6z
110000 297.702 -1.67969 0.81919 -222.65799 1.67969 -0.81919 4.20516
110500 301.11943 -0.13162 2.90778 -221.06796 0.13162 -2.90778 2.61513
Thanks in advance,
Lingfei
