Dear lammps users,
I have some questions concerning energy minimization. I know that unlike “fix nve” which do time integration, “minimize” find the nearest pe-minimum geometry. They both let the system transform to a lower potential energy configuration, so could I fix nve and do minimize in loops at the same time? After “minimize”, force calculated will be zero? If I want to get strain-stress property of the system, I should not use “minimize” in the loading procedure, right?
Thank you so much.
Michelle
Dear lammps users,
"fix nve" which do time integration, "minimize" find the nearest pe-minimum
no. allso, fix nve does not remove energy from the system, so potential
energy is converted to kinetic energy or vice versa. to get to a minimum
from this, you have to remove (kinetic) energy.
After "minimize", force calculated will be zero?
sometimes.
"minimize" in the loading procedure, right?
have you had a look at some papers where people describe how they computed
such properties?
Thank you for your advice.
