Dear lammps users,
I'm trying to print part of my data to a file using fix print. But the problem is I don't need my output data in a sequential time like every 100 time steps. So basically I'm trying to do something like below:
fix VACF_out_print all print v_s "\{t\} {diff} \{vacf1\} {vacf2} \{vacf3\} {vacf4}" append VelAutoCoDiff.txt screen no
in which "s" is a variable containing the time intervals which I need. This time steps has been read by lammps via an input file like:
variable f file logpointsquench.dat
variable s equal next(f)
So the idea came from the fact that I have already used this method for outputting some other data, but with dump and dump modify as below :
dump my_dump all custom 1 sort/out* id xu yu zu
dump_modify my_dump append no every v_s sort id format line "%d %20.15g %20.15g %20.15g"
The problem is I can not use dump for VACF as is works with particle IDs and prints out per/atom data. That's why I'm trying to use fix print but it does not work.
First of all the variable should be given to it like ${s} and then it does not understand that it should print the data at every specific time step which v_s has.
So does any of you have any idea whether it is possible to modify fix print to write data in a none sequential time or not?
Regards
Mehrdad
