I am trying to simulate dipoles with explicit solvent molecules and try to observe the effects in an electric field. I want the solvent molecules not to be dipoles
Can I add dipole movement to a few atoms in the simulation ( keep the atom_style atomic) so as to have point dipoles, using the fix property/atom command.
If yes can you please explain how
Regards
Nishanth
to be dipoles
command.
there is no need to do this. just use atom style dipole (or a hybrid
of dipole and whatever else you need) and just assign a zero dipole
moment to those atoms without.
Thanks for replying,
I have three problems
- Whenever I us pair_style dipole it says pair style dipole/cut has an error because some torque, dipole moment charge have not been specified. I seen someone ask a similar question to you in the past but I couldn’t understand the answer given by you. You suggested something like you need to chose a proper atom_style. could you explain
2)When I give zero dipole moment to dipoles does lammps take it as just spherical particles or it considers them as dipoles (separated +ve and -ve charge but with zero dipole moment )
3)what is the default charge the dipoles take if I do not specify. is it the overall charge given to the dipole ( because dipoles need to be neutral right) or just q of the +q and -q separated charges
Regards
Nishanth
All I could say is written in the manual. Please read up on this.
Neither. By default particles are point particles and if you add dipoles, they are point dipoles, not pairs of point charges.
This statement/question makes no sense. Please see my answer to 2) and think about this. It may help to read about multipoles in a textbook on electrostatics.
Axel
Atom_style hybrid sphere dipole
will allow you to assign point dipoles
to spherical particles. You can also
assign point charges, but those are 2
different attributes.
