I have a pb with fix reaxcbonds : when I use it with many cores (>6 in my case, but it depends on the memory on the cluster node…), the required memory increases and overflows the available one.
The output are given : from 1 to 6 cores the calculation is ok, above 7 either the primary allocation crashes (if I work on only one node with 40GB RAM) or swaps.
The input are given also.
My question : how is made the allocation per core for fix reaxcbond ?
Thank you in advance,
Alexandre BARTHELEMY|R&D Engineer
T. +33 (0)4 38 92 17 30
alexandre.barthelemy@…3997… | www.soitec.com
Soitec | Parc Technologique des Fontaines, 38190 Bernin (France)
Ce message, ainsi que tous les fichiers joints, est exclusivement destiné aux personnes dont le nom figure ci-dessus. Il peut contenir des informations dont la divulgation est à ce titre rigoureusement interdite. Dans l’hypothèse où vous avez reçu ce mail par erreur, merci de le renvoyer à l’adresse email ci-dessus et de détruire toute copie.
This message and any of the attachments may contain proprietary material for the sole use of the intended recipient. Any review or distribution by others is strictly prohibited. If you are not the intended recipient please contact the sender and delete all copies.
data_pass.silicon (166 KB)
quench.in (3.55 KB)
6cores_OK.out (3.55 KB)
7cores_error.out (4.04 KB)
8cores_swap.out (2.17 KB)
10cores_error.out (4.74 KB)
12cores_error.out (5.19 KB)
ffield.reax (17.9 KB)
