I am trying to set fix rigid for a carbon nanotube but get the error:
ERROR: Illegal fix/rigid command
For this error, the manual says to check syntax, but the syntax looks fine:
fix 2 SWCNT rigid molecule temp {TEMP} {TEMP} ${TDAMP}
The first fix all NPT, so could the problem be that I need to take the SWCNT group out of the NPT fix for this to work?
Fred
fix 2 SWCNT rigid molecule temp \{TEMP\} {TEMP} ${TDAMP}
The syntax is not fine. If you read carefully the doc page:
"The temp and tparam keywords apply a Nose/Hoover thermostat to the
NVT time integration performed by the rigid/nvt style. They cannot be
used with the rigid or rigid/nve styles."
This does not cause the error, but you should indeed take the SWCNT
group out of the NPT fix, otherwise you will be time-integrating the
atoms of this group twice.
Laurent
