Hi All,
I realized after the fact, that the fix rigid does not work with minimize. Is there any workaround that won’t distort the bonds on the rigid particles?
Fred
Hi All,
Fred
In case it is of use to someone else, someone gave me a good answer to this question which uses “fix setforce”. It works when unoverlapping is the only objective …
To the rigid molecule(s) apply:
fix freeze RIGIDSTUFF setforce 0.0 0.0 0.0
minimize …
unfix freeze
fix N RIGIDSTUFF rigid molecule
Getting the minimizers to work with constraints like
SHAKE or fix rigid is non-trivial. I don't know how
to do it correctly. So LAMMPS doesn't do it.
