I am using current release of LAMMPS for NEB calculations.
I am interested in calculation of the energy barrier associated with hopping of a rigid CO2 molecule through a small pore window in a rigid porous structure.
Although, I have used proper “fix rigid” command for my NEB molecule, I have noticed that atomic structure of CO2 is changing during the minimization process!
I wonder if anybody has a clue on the cause of this problem. Input script is attached for your consideration.
what does "current" mean? it can change every day. please specify the
exact version as printed.
structure.
hmm... do you think NEB is a good method for that? you only get the
potential energy barrier, but for a process like you describe, this
may not show the whole picture. what would be much more descriptive is
the *free* energy barrier, as that would also include the (likely to
be significant) entropy contributions.
process!
the clue is in the documentation:
These fixes are not invoked during energy minimization.
NEB is a minimization technique. Many fixes are not
supported during minimization unless they are documented
to do so. Fix rigid is not. I.e. you also can’t perform
a minimize command on a rigid body.
