dear all
I have a simple system with data file attached below and i made it rigid with the below code and i ran it for 200000 femtosecond in order to relax it but it keeps moving and rotating and never reaches the desired temperature which is 310 k.
i would appreciate if someone help me.
sincerely
shahriar dadras
my code:
units real
atom_style full
pair_style buck/coul/cut 10.0 8.0
read_data buckdata.data group nanoparticle
set type 1 charge 1.68 # nanoparticle1 F
set type 2 charge 1.6 # nanoparticle1 Fe
set type 3 charge -1.22 # nanoparticle2 O
pair_coeff 1 3 25421.94 0.3299 0 10.0
pair_coeff 2 3 18730 0.3399 0 10.0
pair_coeff 3 3 524950 0.149 15 10.0
pair_coeff 1 1 0 1 0 10.0
pair_coeff 2 2 0 1 0 10.0
pair_coeff 1 2 0 1 0 10.0
velocity all create 310.0 12345678 dist uniform rot yes
special_bonds charmm
thermo 1
thermo_style multi
timestep 1.0
dump 1 all atom 10 membrane.lammpstrj
minimize 0.00001 0.0001 1000000 10000000
fix rigid nanoparticle rigid/nvt molecule temp 310 310 20
reset_timestep 0
dump 2 all atom 100 membrane2.lammpstrj
compute sss nanoparticle temp
compute fff nanoparticle temp/com
thermo 10
thermo_style custom step temp press etotal pe ke c_fff
run 200000
buckdata.data (16.6 KB)
