Hello all,
I want to add a force on each atom in a group. The force equation is like F®=-k0*(z-z0)*H(z-z0). Here, K0 represents force constant(so, it is a constant). z represents the current z coordinate of the atom. z0 is also a constant. H(z-z0) is heaviside step function. When z=z0, H(z-z0)=0.5. When z<z0, H(z-z0)=0. When z > z0, H(z-z0)=1. I would like to use setforce command for this purpose. But I don’t know hot to set a force based on the coordinate of the atom.
Does anybody know how to do it? I appreciate any help.
Thanks in advance!
Hang
Hello all,
F(r)=-k0*(z-z0)*H(z-z0). Here, K0 represents force constant(so, it is a
command for this purpose. But I don't know hot to set a force based on the
create an atom style variable "name", compute your force contribution
and then use v_name as the z-coordinate of fix addforce(!)
Carol posted a similar question/example to the mailing list recently
on this topic:
http://sourceforge.net/mailarchive/message.php?msg_id=29644875
(Click on the follow-up messages (replies) to see the corrected input script.)
(To implement the Heaviside function, I imagine you can implement this
using "if" statements to set the value of your variable.)
Cheers
Andrew
