Dear All,
I am using LAMMPS (14 Feb 2014) and have some questions about fix setforce simulation:
I want to fixed the atoms in the outmost region to make a fixed boundary and use ‘fix setforce’ command, such as:
fix 1 cold setforce 0.0 0.0 0.0 #to fix the atoms in group ‘cold’
And then, I want to keep the atoms in group ‘cold’ at 0.01K at the same time. Could I use the following two commands together?
fix 2 cold nvt temp 0.01 0.01 0.1
Although, the two commands running is ok, and I didn’t get any error. However, I am not sure whether ‘fix setforce’ will affect the time integration and the update of the position and the velocity for atoms in the group?
Dear All,
simulation:
use 'fix setforce' command, such as:
fix 1 cold setforce 0.0 0.0 0.0 #to fix the atoms in group 'cold'
And then, I want to keep the atoms in group 'cold' at 0.01K at the same
Although, the two commands running is ok, and I didn't get any error.
However, I am not sure whether 'fix setforce' will affect the time
group?
yes it does. if you want to have atoms move with a given kinetic
energy that corresponds a particular temperature, but not leave their
general location, you cannot use setforce. setforce 0 0 0 wipes out
all computed forces and thus, provided the atoms have *no* kinetic
energy, they will remain immobile. what appears to me that you want is
to use fix spring/self, which will allow atoms to move, but restrain
them to their initial location with a harmonic potential.
