Fix shake command issue
Dear Sir/Madam,
I am trying to simulate a rigid molecule of water model TIP4P/2005 using the fix shake command
in NPT and it keeps comes the following error even for serial or parallel program and also in a pc or
a cluster.
The following error is:
LAMMPS (11 Aug 2017)
Reading data file …
orthogonal box = (0 0 0) to (14 14 14)
reading atoms …
3 atoms
scanning bonds …
2 = max bonds/atom
scanning angles …
1 = max angles/atom
reading bonds …
2 bonds
reading angles …
1 angles
Finding 1-2 1-3 1-4 neighbors …
special bond factors lj: 0 0 0
special bond factors coul: 0 0 0
2 = max # of 1-2 neighbors
1 = max # of 1-3 neighbors
1 = max # of 1-4 neighbors
2 = max # of special neighbors
Replicating atoms …
orthogonal box = (0 0 0) to (98 98 98)
1029 atoms
686 bonds
343 angles
686 atoms in group hydrogen
343 atoms in group oxygen
ERROR: Unknown fix style shake (…/modify.cpp:854)
Last command: fix constrain all shake 0.0001 100 0 b 1 a 1
Thanks for your time. I am looking forward to your answer.
Chris
Fix shake is a part of the RIGID package (as the manual states). Did you compile LAMMPS with it?
Michal
