fix shake
hello dear
i want to simulate water and nano fluid cu in a fcc lattice…water is base fluid and cu is a region (sphere or box)in the center of lattice (between water)
i have read the manuel and know this that( , the two H atoms might
exert a repulsive force on each other ) should i use fix shake just for hydrogen or water.?(which fix shake should i use in my input code ?.and is this sentence true that there is no need to use "neigh_modify "when i use “fix shake”.)???
i appreciate any help
thanks
regard
atom_style full
bond_style harmonic #hybrid harmonic
angle_style harmonic #hybrid harmonic
kspace_style pppm 1.0e-5
#pair_modify mix arithmetic
read_data water.data
group hydrogen type 1
group Water type 1 2
group cu type 3
group oxygen type 2
lattice fcc " 3. 615" #Cu lattice constant
region Cu sphere 0 0 0 7 units box
create_atoms 3 region Cu
set group oxygen charge -1.040
set group hydrogen charge .520
set group cu charge 0.000
pair_style hybrid lj/cut/coul/long 0.1521 3.157 eam lj/cut 3.157 # 7.5
pair_coeff 1 1 lj/cut/coul/long 0.0460 0.4000 #H-H epsilon sigm # 108.0e-21 32.0e-11
pair_coeff 1 2 lj/cut/coul/long 0.0836 1.7753 #O-H epsilon sigma
pair_coeff 1 3 lj/cut 0.6589 0.2117 #H-Cu epsilon sigma
pair_coeff 2 2 lj/cut/coul/long 0.1521 3.157 #O-O epsilon sigma # 0 0
pair_coeff 2 3 lj/cut 1.198 1.587 #O-Cu epsilon sigma
pair_coeff 3 3 eam cu.eam #Cu-Cu
for cu-cu bond sigma=.227 epsilon(Lj)=.583 ev # sigma=2.34 epsilon=9.4512 kcal/mol
bond_coeff 1 450 0.9572 #O-H
angle_coeff 1 55 104.52 #H-O-H
++++++++++++++++setting+++++++++++++++++++++
neighbor 2 bin
#neigh_modify delay 0 every 1 check yes #Unlike “fix rigid”, there is no need to use "neigh_modify
exclude" if you use “fix shake”
---------- compute ----------------------------------------
compute 1 all temp
#compute heat/flux
compute peatom all pe/atom
compute keatom all ke/atom
dump 1 all custom 10000 dump.equilibrium. xs ys zs vx vy vz
---------- output----------------------------------------------
thermo 100
thermo_style custom step etotal enthalpy pe press ke
velocity all create 373.0 4928459 rot yes dist gaussian #23482341
fix 1 2 water npt temp 300 300 100 iso 0 0 1000
fix water shake 1.0e-4 200 0 b 1 a 1
fix 1 all shake 1e-6 500 0 m 1.0 #for hydrogen
hello dear
i want to simulate water and nano fluid cu i…water is base fluid and cu is a region (sphere or box)in the center of lattice (between water)
when i run it shows this error"couldn’t find group id"
i also have read the manuel.and defined the group in input code (group hydrogen type 1 …)
does anybody know the error?
thanks
regard
atom_style full
bond_style harmonic
group cu type 3
group oxygen type 2
neighbor 2 bin
compute 1 all temp
#compute heat/flux
thermo 100
hello dear
I HAVE WORKED somedays to correct the error but i could’nt.it’s about fix npt and fix shake.
can anybody help me to modify the error?
thanks
regard
atom_style full
bond_style harmonic
group cu type 3
group oxygen type 2
neighbor 2 bin
thermo 100
compute 1 all temp
#compute heat/flux
Please keep in mind that all LAMMPS variables are “case sensitive”. “Water” does not equal to “water”.
Also, you have to correct your Cu lattice constant.
Ray
hello dear
exert a repulsive force on each other ) should i use fix shake just for hydrogen or water?
thanks
regard
atom_style full
group cu type 3
group oxygen type 2
neighbor 2.0 bin
---------- Relaxation -----------------------------------------
minimization : avoid atoms overlapping
min_style fire
min_modify dmax 0.01
minimize 1.0e-10 0 100000 1000000
#(the minimization step is not necessary in this example. However
in general, it’s always a good idea to minimize the system beforehand.
fSHAKE was defined in system.in.settings. It is incompatible with “minimize”.
#unfix fSHAKE
#minimize 1.0e-5 1.0e-7 100000 400000 )
#------------------------dump--------------------------------
dump 1 all custom 10000 dump.equilibrium. xs ys zs # vx vy vz
thermo 100
thermo_modify flush yes
#+++++++++++++++++++++++++++++++fix ++++++++++++++++++++++++++++++++
velocity all create 300.0 4928459 rot yes dist gaussian #23482341
fix 1 hydrogen shake 1e-6 500 0 m 1.0 a 1 #for hydrogen
fix 12 water npt temp 300.0 300.0 100.0 iso 0.0 0.0 1000.0
compute 1 all temp
#compute heat/flux
#fix 12 all thermal /conductivity 100 z 20
#fix 12
hello dear
thanks
regard
atom_style full
group cu type 3
group oxygen type 2
neighbor 2.0 bin
min_style fire
#unfix fSHAKE
thermo 100
compute 1 all temp
#compute heat/flux
#fix 12
