That sounds right. What I'm really saying is that
if you insure the image flags are correct at the time
you invoke fix spring/self, then I think it should work
fine with periodic BC. This needs to be added to
its doc page.
I did send a copy to the list as soon as I noticed this faux pas. Unfortunately default behavior for gmail is replying to sender rather than list.that’s why you see so many" keep the list in the loop" mails
list.that's why you see so many" keep the list in the loop" mails
FWIW: the default setting for gmail can be changed to reply to all.
