Hello dear all,
I am trying to fix two groups of atoms in their initial positions using fix spring self command. The two groups are two graphene sheets. I fixed them in z direction and xy plane.
The documentation says fix spring/self computes a scalar(energy) value using 0.5Kr^2. while r is the displacement from initial position. So defining a variable r = sqrt(“fix spring/self value”/0.5/k) i should be able to calculate r.
when their potential force gets equal to spring/self force, they get stabled and almost fixed. now I want to calculate the spring force which is -k*r.
I also have defined a variable (D) to compute the distance of two sheets in z direction.
regarding the fact that groups don’t move in xy plane, i expected the two variables(D & r) to be approximately equal. However they are different by almost 2-3 orders of magnitudes! Am I getting the meaning of r wrong?
here is the commands I used in input script:
group g1 id <> 1 180
group g2 id <> 181 360
compute cg1 g1 com
compute cg2 g2 com
fix 1 g1 rigid single
fix 2 g2 rigid single
fix g1 g1 spring/self 3 z
fix g11 g1 spring/self 3 xy
fix g2 g2 spring/self 3 z
fix g22 g2 spring/self 3 xy
fix 3 all nvt temp 300.0 300.0 10
variable D equal (c_cg2[3]-c_cg1[3])
variable R equal sqrt(f_g1/0.5/3)
variable F equal -3*v_R
