Hii …
I was using the following command for fix srd
fix 2 small srd 20 big 1.0 0.25 49894 shift yes 54979 &
search 0.2 collision slip inside ignore overlap yes
Here, groupbig-ID is set as big and the mass was set 1.0
My problem is when I set the mass value 1.0 or higher than that the input script runs fine. But if I set the mass lower than 1.0 such as 0.1 or 0.01 it shows me an error " Fix SRD: bad bin assignment for SRD advection (…/fix_srd.cpp:756)" and if I set the mass value lower than that such as 0.001 or 0.0001 then shows me error " Lost atoms: original 270 current 227 (…/thermo.cpp:430)"!!!
May I know the way to get rid of this error and make the file run fine ?
Thanks in Advance.
Regards,
Salehin
