(1) I have a copy of LAMMPS (9 Jan 2020 compiled with GCC) which
sometimes segfaults when asked to initialize a fix store/state with a
per-atom compute:
compute foo all pe/atom pair #also with ke/atom, chunk/atom type
#run 0
fix foobar all store/state 1 c_foo
or per-atom variable:
variable foo atom x*y
#run 0
fix foobar all store/state 1 v_foo
I have tested this on two different systems (an all-atom ionic liquid in
bulk with 4800 atoms, and a acetonitrile-solute system between
electrodes from lammps-conp with 432 atoms). In both cases I get an
occasional segfault when starting up the run (with the run proceeding
normally otherwise), with the 4800-atom system segfaulting more often
than the 432-atom system. Inserting "run 0" before the store/state fix
prevents the segfault, suggesting that some memory is (sometimes!) not
properly assigned before the system has been fully setup.
Valgrind traces the error to line 550 in end_of_step() in
fix_store_state.cpp:
if (cfv_any && nevery) {
const bigint nextstep = (update->ntimestep/nevery)*nevery + nevery;
modify->addstep_compute(nextstep);
but I don't understand why that went wrong. Is it that the update /
modify structures need a run 0 to be properly assigned?
Also, I have two copies of LAMMPS (on a HPC) compiled with Intel
compilers, dating to 5 Jun 2019 and 9 Jan 2020 respectively, which do
not replicate this behavior (that is, fix store/state works with no
segfault, even without "run 0").
What can I do about this bug (assuming it replicates on other machines)?
