I am use a simple case to text fix/ttm:
fix 0 all ttm 699489 0.212 67.448 441.36 0.0058 0.0157 1 1 6 InitialTs 10 Cu.out
There is an error: Expected integer parameter in input script or data file (…/fix_ttm.cpp.69)
Last command: fix 0 all ttm 699489 0.212 67.448 441.36 0.0058 0.0157 1 1 6 InitialTs 10 Cu.out
InitialTs:
0 0 0 1
0 0 1 1
0 0 2 1
0 0 3 1
0 0 4 1
0 0 5 1
I checked the manual and InitialTs file, and no floating value is used in InitialTs. I still do not understand where the problem is.
Any help would be appreciated!
Luke
