Hello All,
If anyone could suggest me the way how to fix the global quantity if it is VECTOR not scaler?
I was trying to find msd for atoms using the following fix which works perfectly.
fix 9 small vector 10 c_msd_s[4]
where msd_s is
step v_1 v_2 v_3 v_4
100 0.00150519 0.00139206 0 0.00289726
200 0.00390091 0.00340854 0 0.00730945
300 0.00718023 0.00600874 0 0.013189
but when I tried to find msd for molecules using
fix 15 big vector 10 c_msd_b[:][4] it does not working. COULD ANYONE PLEASE CORRECT MY THIS COMMAND SO THAT I COULD FIX THE 4th COLUMN OF EACH ROW ? I have already calculated msd/chunk to using the chunkID. All i need now is to fix this quantities and apply on a varible.
variable twopoint_b vector c_msd_b[4]/4/(step*dt+1.0e-6)
where msd_b is
step v
v_1 v_2 v_3 v_4
100 3
1 9.31923e-007 0.000729263 0 0.000730195
2 0.000379746 7.76286e-005 0 0.000457375
3 6.24798e-006 4.50904e-008 0 6.29307e-006
200 3
1 8.76573e-005 0.00309897 0 0.00318663
2 0.0018359 0.000484568 0 0.00232047
3 2.17143e-005 4.99036e-007 0 2.22133e-005
Thanks.
Regards,
Salehin
Hello All,
VECTOR not scaler?
perfectly.
where msd_s is
*of course* it is not working. this is incorrect syntax. where in the
LAMMPS manual does it say, that you can use this syntax?
you cannot invent some syntax and then expect the people on the mailing
list to do your thinking for you.
i would suggest a much simpler solution: rather than computing the MSD for
the whole molecule, just pick one reference atoms - preferably close to the
center of mass - and compute the MSD for those atoms. at the time scale
where the MSD is meaningful converged, the difference of the MSD between
individual atoms in a molecule to their average is negligible compared to
the statistical and systematical error. no crazy syntax modification or
LAMMPS hacking required.
