Hi Dear LAMMPS users
Why doesn’t work fix wall/lj126 in simulations!!?
for Example ,if I simulate Poiseuille flow and replace this command instead of Wall Molecules , I don’t get appropriate results (like Velocity Profile)?? i get negative Pressure!!
Thanks a lot from your attention
Iman Tasdighi
hi iman,
please calm down. there is no need to use that
many exclamation marks or question marks.
Why doesn't work fix wall/lj126 in simulations!!?
it does work fine.
of Wall Molecules , I don't get appropriate results (like Velocity
the wall potential does what it says it does.
it has no roughness, so please explain why
it should induce a velocity profile?
if you get a negative pressure, you are likely
not using it right. however, if you are not using
a feature correctly, that doesn't automatically
mean that this feature is broken. please keep
that in mind.
thanks,
