> Hello,
> Do not understand how this expression:
> "For fixes that calculate a contribution to the potential energy of the
> system " ( fix_modify )
> is related to the change in energy that makes the rescaling of velocities
> fix temp / rescale .
there is no relation.
> Why the velocity rescaling contributes to the energy
> potential of the system ? .
where does it say so. fix temp/rescale changes the kinetic energy.
Reach that conclusion when observing the output of thermo style, when I use
fix_modify energy .
With fix control_temp all temp/rescale 1 94.4 94.4 2 1, the following
calculation:
*- When using the " fix_modify FIX-ID energy yes" command I get the
following output:*
Step Temp TotEng KinEng PotEng
f_control_temp
0 120 -6.892267e-18 2.1447023e-18 -9.0369694e-18
0
1 94.4 -6.8922733e-18 1.6871658e-18 -8.5794391e-18
4.5561603e-19
2 94.121879 -6.8922855e-18 1.6821951e-18 -8.5744806e-18
4.5561603e-19
3 93.663783 -6.892305e-18 1.6740078e-18 -8.5663128e-18
4.5561603e-19
4 93.013166 -6.8923318e-18 1.6623796e-18 -8.5547114e-18
4.5561603e-19
5 94.4 -6.8923652e-18 1.6871658e-18 -8.579531e-18
4.1545742e-19
6 93.294519 -6.8924064e-18 1.6674081e-18 -8.5598145e-18
4.1545742e-19
7 94.4 -6.8924526e-18 1.6871658e-18 -8.5796185e-18
3.7126644e-19
8 92.719102 -6.8925045e-18 1.657124e-18 -8.5496284e-18
3.7126644e-19
9 94.4 -6.892655e-18 1.6871658e-18 -8.5798208e-18
3.053427e-19
10 94.4 -6.8923995e-18 1.6871658e-18 -8.5795653e-18
2.6220489e-19
The energy changes ( due to thermostat ) increase the potential energy of
the system ,* maintaining a constant energy(aprox.)*.
What does the idea of adding the change of energy ( due to the
thermostat ) , to the potential of the system ?.
It is to maintain constant energy? this option has any effect on my
simulation or just to display information on the screen ?
I'm confused
*- on the other hand " FIX- ID fix_modify energy no" shows the following:*
f_control_temp
0
1 94.4 -7.3478893e-18 1.6871658e-18 -9.0350552e-18
4.5561603e-19
2 94.121879 -7.3479015e-18 1.6821951e-18 -9.0300966e-18
4.5561603e-19
3 93.663783 -7.3479211e-18 1.6740078e-18 -9.0219288e-18
4.5561603e-19
4 93.013166 -7.3479478e-18 1.6623796e-18 -9.0103274e-18
4.5561603e-19
5 94.4 -7.3078226e-18 1.6871658e-18 -8.9949885e-18
4.1545742e-19
6 93.294519 -7.3078638e-18 1.6674081e-18 -8.9752719e-18
4.1545742e-19
7 94.4 -7.2637191e-18 1.6871658e-18 -8.9508849e-18
3.7126644e-19
8 92.719102 -7.2637709e-18 1.657124e-18 -8.9208949e-18
3.7126644e-19
9 94.4 -7.1979977e-18 1.6871658e-18 -8.8851635e-18
3.053427e-19
10 94.4 -7.1546044e-18 1.6871658e-18 -8.8417702e-18
2.6220489e-19
in this case the energy of the system varies
> I want to simulate the argon rahman 1964 , using a rescaling of
temperature,
> however , I worry that the energy change introduced by the thermostat
> directly affect the results of the simulation, for that reason is that
> monitoring.
of course, it does affect the simulation. quite significantly. every
time rescaling happens, it is as if every atom in your system is given
a kick. if you want to reproduce those very old simulations, just run
with fix nve alone.
If I run only NVE , as you would expect the temperature fluctuates a lot.
Rahman (1964 ) controlled the temperature using a rescaling of velocities ,
which is why I'm using temp / rescale .
