Hi all,
I'm facing an infinite loop when using the forcezero line search option in association with cg method for minimization. I checked that it occurs in the "while" cycle which starts at line 713 of min_linesearch.cpp
This is the output (LAMMPS gets stuck after step 22):
LAMMPS (16 Oct 2012)
using OpenMP capable neighbor list subroutines
Reading data file ...
orthogonal box = (0 0 0) to (101.909 50.9442 20)
2048 atoms
280 atoms in group llead_g
280 atoms in group rlead_g
WARNING: Resetting reneighboring criteria during minimization (min.cpp:173)
Last active /omp style is pair_style airebo/omp
Setting up minimization ...
Memory usage per processor = 5.47567 Mbytes
Step PotEng Lx Ly Lz Press Temp Pxx Pyy Pzz eatoms
0 -15142.272 101.909 50.9442 20 832.03309 0 -5266.5591 7699.2748 63.383642 -15142.272
1 -15147.261 101.909 50.9442 20 919.76054 0 -5254.6168 7867.1711 146.72728 -15147.261
2 -15149.367 101.909 50.9442 20 542.61529 0 -5981.3534 7527.5103 81.688923 -15149.367
3 -15150.611 101.909 50.9442 20 381.35529 0 -6231.3015 7334.2809 41.086456 -15150.611
4 -15151.058 101.909 50.9442 20 486.55991 0 -6005.2307 7387.9058 77.004613 -15151.058
5 -15151.856 101.909 50.9442 20 359.49213 0 -6231.1135 7250.6953 58.894541 -15151.856
6 -15152.309 101.909 50.9442 20 293.72721 0 -6328.455 7159.5675 50.069101 -15152.309
7 -15152.659 101.909 50.9442 20 309.26973 0 -6300.584 7170.0465 58.346727 -15152.659
8 -15152.81 101.909 50.9442 20 295.06347 0 -6331.5348 7161.7655 54.959712 -15152.81
9 -15152.959 101.909 50.9442 20 251.8733 0 -6370.7283 7082.938 43.410203 -15152.959
10 -15153.247 101.909 50.9442 20 216.56462 0 -6437.8627 7052.3982 35.158336 -15153.247
11 -15153.393 101.909 50.9442 20 194.91924 0 -6478.2271 7027.6632 35.321638 -15153.393
12 -15153.561 101.909 50.9442 20 156.02958 0 -6504.8775 6941.9194 31.046929 -15153.561
13 -15153.699 101.909 50.9442 20 122.41328 0 -6559.3093 6908.3904 18.158709 -15153.699
14 -15153.806 101.909 50.9442 20 100.39928 0 -6590.5626 6876.6643 15.096223 -15153.806
15 -15153.901 101.909 50.9442 20 78.198693 0 -6583.5281 6805.2131 12.911042 -15153.901
16 -15153.974 101.909 50.9442 20 59.063237 0 -6601.6549 6771.1583 7.6863143 -15153.974
17 -15154.042 101.909 50.9442 20 46.525476 0 -6638.7233 6773.8881 4.4116645 -15154.042
18 -15154.082 101.909 50.9442 20 38.678401 0 -6640.2056 6752.0344 4.2063587 -15154.082
19 -15154.124 101.909 50.9442 20 30.35124 0 -6639.3552 6725.097 5.311953 -15154.124
20 -15154.141 101.909 50.9442 20 28.609325 0 -6653.6722 6735.3393 4.160866 -15154.141
21 -15154.173 101.909 50.9442 20 27.453346 0 -6662.13 6741.6389 2.8510883 -15154.173
22 -15154.199 101.909 50.9442 20 28.409203 0 -6649.3615 6729.7183 4.87085 -15154.199
It happens both in serial and in parallel mode on all machines I tried (AMD, Intel...) but, unfortunately, I didn't manage to reproduce it on a small system (I have 2048 atoms).
My LAMMPS version is 28-Oct-2012 and I use CH.airebo potential.
Could it be that the list of possible exit criteria has not been exhausted in the code? Or, it's just that I have a pathological system?
I attached my script and my data file (script.in and 2_1.gra).
Bests
Fernando
script.in (1.09 KB)
2_1.gra (67.7 KB)
