Free energy of insertion
Thank you very much for your suggestions. I still want to try the method described in the following work (widom insertion).
http://www.ncbi.nlm.nih.gov/pubmed/21141921
although other suggestions and free energy perturbation techniques are incorporated in lammps, I will try them later.
I am going to go with axel suggestion that is compile lammps as library and use custom C++ code for insertion and calculation of (deltU).
I also have other option: To use a python code inside a lammps script since I can access the co-ordinates by atom style variable and pass it in the python code
Out of these two (c++ and python from input script) which one would be faster or is it hard to say ?
Arun
