Dear All,
I have a conceptual doubt regarding freezing of the atoms in the crystal during minimization in order to mimic the semi-infinite crystal surface. The following procedure has been used in order to create the semi-infinite crystal surface of Aluminium.
- Calculate lattice constant at the desired temperature
- Use the lattice constant calculated to create atoms in the region to make a slab
- Freeze (by using setforce command) lower half portion of the slab and minimize the system
- Unfreeze (Unfix the setforce) lower half portion and equilibrate at the desired temperature
I am freezing the lower half of the slab to get bulk like characteristics below the free surface to mimic the semi-infinite surface. My question is when we unfreeze and equilibrate the system doesn’t the previously frozen atoms will minimize eventually with time? I visually compared two sets (with and without freezing) of simulation and I can see that at the end of the equilibration both the simulations give the same parametric value (Potential Energy).
Thank you
