Friction coefient calculation getting error in thermo style
i want to calculate friction between water and graphite…
#LAMMPS Input file generated by Avogadro
MD simulation for SPCE
units real
variable T equal 283.15 #86.4956
variable V equal vol
variable dt equal 1
variable p equal 5000 # correlation length
variable s equal 10 # sample interval
variable d equal $p*$s # dump interval
convert from LAMMPS real units to SI
variable kB equal 1.3806504e-23 # [J/K/** Boltzmann
variable atm2Pa equal 101325.0
variable A2m equal 1.0e-10
variable fs2s equal 1.0e-15
variable convert equal {atm2Pa}*{atm2Pa}{fs2s}*{A2m}{A2m}*{A2m}
units real
atom_style full
#The SPC/E water potential
pair_style lj/cut/coul/long 12 12
kspace_style ewald 1.0e-4
pair_coeff 1 1 0.15535 3.1533
pair_coeff * 2 0.00000 0.0000
bond_style harmonic
angle_style harmonic
read_data data.lammps
bond_coeff 1 100.00 1.000
angle_coeff 1 100.00 109.47
#special_bonds lj/coul 0.0 0.0 0.5
group water type 2 3
group graphite type 1
neighbor 2.0 bin
timestep ${dt}
thermo $d
variable v equal vol
print “volume: $v”
fix RigidOHBonds water shake 0.0001 20 0 b 1 a 1
fix freeze graphite setforce 0.0 0.0 0.0
velocity water create 260 4928459 rot yes mom yes dist gaussian
velocity graphite create 260 4928459 dist gaussian
fix ensemble water nvt temp $T $T 10 drag 0.2
compute tgraph graphite temp
compute twater water temp
thermo_style custom step temp c_tgraph c_twater pe etotal press vol density
thermo 10
#unfix NVT
fix NVE all nve
reset_timestep 0
variable p equal 1000 # correlation length
variable s equal 2 # sample interval
compute force water group/group graphite
variable fxy equal fxy
variable fxz equal fxz
variable fyz equal fyz
fix SS all ave/correlate $s $p d & v_fxy v_fxz v_fyz type auto file vis.dat ave running variable scale equal {convert}/(${kB}$T)$V*s*{dt}
variable la11 equal trap(f_SS[3]){scale} variable la22 equal trap(f_SS[4])*{scale}
variable la33 equal trap(f_SS[5])
${scale}
variable la equal (v_la11+v_la22+v_la33)/3.0
variable ndens equal count(all)/vol
thermo_style custom step temp press v_fxy v_fxz v_fyz v_la11 v_la22 v_la33 v_la
print “average frictioncoeffient”
Run the simulation
run 900000
i want to calculate friction between water and graphite...
so is there a question here?
please note, that this mailing list is not a "debug my input file"
service. you can (and should) do that on your own.
http://lammps.sandia.gov/doc/Section_errors.html
