There are some problems in the NATDEF tag in Reaxff
/* NATDEF = Max number of atoms
#define NATDEF 40000
This is the default. And I can successfully compiled
But when I increase this NATDEF 40000 to 70000, it fails to compile.
reax_inout.F:(.text+0x2275): relocation truncated to fit: R_X86_64_PC32 against symbol `cbktregime_’ defined in COMMON section in …/…/lib/reax/libreax.a(reax_inout.o)
reax_inout.F:(.text+0x2298): relocation truncated to fit: R_X86_64_32S against symbol `cbkrestr_’ defined in COMMON section in …/…/lib/reax/libreax.a(reax_inout.o)
reax_inout.F:(.text+0x229f): relocation truncated to fit: R_X86_64_32S against symbol `cbkrestr_’ defined in COMMON section in …/…/lib/reax/libreax.a(reax_inout.o)
What is possible reason? And how to fix this?
Thanks for your help.
Best Regards
Zhendong
