Dear,
Thanks a lot for your response.
I have modified the run command to run upto as indicated in the lammps manual. However, I get similar response upon restart as I was getting before with the system going for equilibration at first.
Please find attached a plot showing one of the system properties against the simulation time with the second peak showing the restart.
Please let me know what you think.
Hi Mohamed, I was faced this problem a year ago. That’s why I told you to check your run command. Please read user manual about the run command again and pay attention to the “start” and “stop” options.
Dear,
with the system going for equilibration at first.Please find attached a plot showing one of the system properties against the
simulation time with the second peak showing the restart.Please let me know what you think.
i think that despite your claims of following instructions, you didn't
follow correctly and particularly don't quite understand how LAMMPS
processes its input.
however, this is pure speculation, since you don't provide any proof
that you did indeed do everything properly, while your description
indicates, that your restart is being performed incorrectly.
