FWAction(additions = new_fw, update_spec={}) -> spawned FW doesn't inherit the updated spec
If I have one Firework that has a task with FWAction() that spawns a new firework through additions variable, that new FW that spawns doesn’t seem to inherit any update_spec from the FW that launched it.
Am I doing something wrong?
For example, with this very sample code in CFiretasks.py:
from fireworks.core.firework import FiretaskBase, Firework, FWAction, Workflow
from fireworks.utilities.fw_utilities import explicit_serialize
@explicit_serialize
class TaskUpdateSpec(FiretaskBase):
required_params = []
optional_params = []
def run_task(self, fw_spec):
fw = Firework(SpecPrint())
update_spec={“str1”:“test”}
return FWAction(additions=fw, update_spec = update_spec)
@explicit_serialize
class SpecPrint(FiretaskBase):
print(fw_spec)
And then this helper code in another file:
from CFiretasks import TaskUpdateSpec
from fireworks.core.firework import Firework
t = []
t.append(TaskUpdateSpec())
fw = Firework(t)
When I run this, the only thing that is printed is this in this addition FW:
{'_tasks': [{'_fw_name': '{{CFiretasks.SpecPrint}}'}], '_fw_env': {}}
The update_spec was not passed on.
For anyone who had similar problems, Rees Chang has found a solution that has worked, and I would like to share it with other people who might have similar problems:
Rees pointed out that if you update the addition before you call FWAction, you can get around such a problem:
@explicit_serialize
#Update the FW Spec of new dynamic FW to pass important information - this is the get around:
fw.spec["_fworker"] = fw_spec["_fworker"]
fw.spec[“str1”] = “test”
return FWAction(additions=fw)
Hope this helps!
@explicit_serialize
@explicit_serialize
print(fw_spec)
t = []
fw = Firework(t)
