Dear users and developers,
I am using GCMC-NVT in LAMMPS to study surface adsorption.
The simulation runs without problem. But when I activate the region keyword with GCMC it gets stuck after couple of GCMC trials.
The surface (~ 52 x 52 nm^2) faces Z direction with a large vacuum extending 1.5 — 5 nm .
The adsorbate is roughly the size of a cyclohexane.
I like to limit the GCMC insertion in the vicinity of surface. Otherwise, after 10^6 steps, GCMC fills the vacuum with adsorbates.
So, I have to either do GCMC with region keyword or shrink the vacuum to ~1nm.
With the second option LAMMPS fails with the “Fix gcmc put atom outside box” error message as I use “boundary p p f” for the slab.
With the region keyword (with large vacuum region) it gets stuck without any error message. The documentation says with the region keyword LAMMPS tries 1000 insertions before moving on to the next step. I think this is causing the problem. I’m wondering if you know a way to overcome this issue.
my LAMMPS version is 12Dec18.
Following is my input.
Thanks for your time.
Sal
units real
neighbor 2.0 bin
neigh_modify delay 1 every 1 check yes
atom_style full
bond_style harmonic
angle_style charmm
dihedral_style charmm
improper_style harmonic
pair_style lj/charmm/coul/long 10 12
pair_modify mix arithmetic
kspace_style pppm 1e-5
kspace_modify order 6
special_bonds charmm
read_data res.data
molecule adsmol ads.txt
group ads type 1:12
region vcm block -27.93 27.93 -26.8535 26.8535 15.0 25.0 side in
velocity all create 300 12345678 dist uniform
variable tfac equal 6.0/3.0
variable mu index -10.0
variable disp index 1.0
compute mdtemp all temp
compute_modify mdtemp dynamic/dof yes
fix md all nvt temp 300 300 100
fix_modify md temp mdtemp
fix mygcmc ads gcmc 100 10 10 0 54341 300 {mu} {disp} mol adsmol &
tfac_insert ${tfac} group ads region vcm
variable adsN atom “type==5”
group adsN dynamic all var adsN
variable nads equal count(adsN)
thermo_style custom step temp press pe ke density atoms v_nads
thermo 100
timestep 1.0
run 1000
