Generating snap potentials
Dear Users,
So I am trying to develop machine learned interatomic potentials, and have installed lammps and using it on python as a module.
Am facing issue in the following code snippets.
I have my lmp executable file installed at this location.
import shutil
lmp_exe = ‘/home/johncahn/.local/bin/lmp’
if lmp_exe is not None and shutil.which(lmp_exe):
print(“LAMMPS executable found at:”, lmp_exe)
else:
print(“Error: LAMMPS executable path is invalid or not found.”)
it as a shared module am able to import in into python.
LAMMPS executable found at: /home/johncahn/.local/bin/lmp
And when i run the bispectrum coefficients snippet am running into this error.
code:
element_profile = {‘Cu’: {‘r’: 0.5, ‘w’: 1.0}}
per_atom_describer = BispectrumCoefficients(rcutfac=2.6, twojmax=6,
element_profile=element_profile,
quadratic=False,
pot_fit=False,
include_stress=False)
Cu_aimd_structures = [d[‘structure’] for d in Cu_aimd_data]
per_atom_features = per_atom_describer.transform(Cu_aimd_structures)
print(“Total # of atoms in Mo AIMD NPT: 108 * 120 = {}\n”.format(sum([len(struct) for struct in Cu_aimd_structures])),
" # of features generated: {} (one feature per atom)\n".format(per_atom_features.shape[0]),
" # of dimensions: {} (for twojmax = 6)".format(per_atom_features.shape[1]))
per_atom_features
error:
TypeError Traceback (most recent call last)
Cell In[26], line 2
1 element_profile = {‘Cu’: {‘r’: 0.5, ‘w’: 1.0}}
----> 2 per_atom_describer = BispectrumCoefficients(rcutfac=2.6, twojmax=6,
3 element_profile=element_profile,
4 quadratic=False,
5 pot_fit=False,
6 include_stress=False)
8 Cu_aimd_structures = [d[‘structure’] for d in Cu_aimd_data]
9 per_atom_features = per_atom_describer.transform(Cu_aimd_structures)
File ~/.local/lib/python3.8/site-packages/maml/describers/_site.py:79, in BispectrumCoefficients.init(self, rcutfac, twojmax, element_profile, quadratic, pot_fit, include_stress, feature_batch, **kwargs)
60 “”"
61 Args:
62 rcutfac (float): The rcutfac used in computing the cutoff between
75 **kwargs: keyword args to specify memory, verbose, and n_jobs.
76 “”"
77 from maml.apps.pes import SpectralNeighborAnalysis
—> 79 self.calculator = SpectralNeighborAnalysis(
80 rcutfac=rcutfac, twojmax=twojmax, element_profile=element_profile, quadratic=quadratic
81 )
82 self.rcutfac = rcutfac
83 self.twojmax = twojmax
File ~/.local/lib/python3.8/site-packages/maml/apps/pes/_lammps.py:291, in SpectralNeighborAnalysis.init(self, rcutfac, twojmax, element_profile, quadratic, **kwargs)
289 self.element_profile = element_profile
290 self.quadratic = quadratic
→ 291 super().init(**kwargs)
File ~/.local/lib/python3.8/site-packages/maml/apps/pes/_lammps.py:82, in LMPStaticCalculator.init(self, **kwargs)
80 if lmp_exe is None:
81 lmp_exe = get_default_lmp_exe()
—> 82 if not which(lmp_exe):
83 raise ValueError(f"lammps executable {lmp_exe} not found")
84 self.LMP_EXE = lmp_exe
File /usr/lib/python3.8/shutil.py:1379, in which(cmd, mode, path)
1367 “”“Given a command, mode, and a PATH string, return the path which
1368 conforms to the given mode on the PATH, or None if there is no such
1369 file.
1374
1375 “””
1376 # If we’re given a path with a directory part, look it up directly rather
1377 # than referring to PATH directories. This includes checking relative to the
1378 # current directory, e.g. ./script
→ 1379 if os.path.dirname(cmd):
1380 if _access_check(cmd, mode):
1381 return cmd
File /usr/lib/python3.8/posixpath.py:152, in dirname(p)
150 def dirname(p):
151 “”“Returns the directory component of a pathname”“”
→ 152 p = os.fspath(p)
153 sep = _get_sep(p)
154 i = p.rfind(sep) + 1
TypeError: expected str, bytes or os.PathLike object, not NoneType
Thanks in advance. Cheers.
You are posting in the wrong forum.
This isn’t a LAMMPS error, but a python error and related to the tool that you are using for fitting since all the errors are pointing to a python package called “maml”. So you need to ask in the corresponding forum or contact the package developers.
Please note that “official” tool used by LAMMPS developers to fit SNAP potentials called FitSNAP is documented here: https://fitsnap.github.io/
okay thank you so much for the reply
