Getting errors while running script in Lammps (ubuntu)
Dear Lammps users,
My lammps was running fine till yesterday but today I am getting the following errors while running input script. Please extend any suggestion why I am getting this error. I didnt install anything new on my work station.
user@…6292…:~/RAJESH/Reaxff/P5/ZZ/H-BN/H-BN_crack_area_2$ mpirun -np 4 lmp_mpi -sf omp -pk omp 4 -in in.bn
Are you sure nothing changed? It seems lammps is unable to find your MPI library, so maybe it got (re)moved or it is no longer in your LD_LIBRARY_PATH?
Dear Stefan,
I am sure I did change nothing. I also installed openmpi again but still getting the same error.
Thanks.
Rajesh
Dear Stefan,
this is a long shot, but have you checked, whether you have an "LCP
infection" in your machine? :wink:
but seriously, it is the very nature of computers to do *exactly* the
same thing when asked to do *exactly* the same thing. so the logical
conclusion is: something *has* to be different. this can be some
environment variable (perhaps reset by some other software that you've
run?) or a permission problem (have you run anything recently using
"sudo"?) or a file system problem.
at any rate, is has to be a local issue and can in *no way* be a LAMMPS issue.
P.S: for people that haven't been around the block as many times as
me: LCP => https://en.wikipedia.org/wiki/Little_Computer_People
Thanks Axel. I compiled lammps again and its working.
