Hi all,
I am getting an illegal NEB command error message even when its in the correct format. Please find below my lammps input script and the initial and final configurations attached. Any help would be appreciated…
Input Script:
Name of the script - Example
atom_style atomic
#--------Reading Configuration----------
read_data configforrunwithoutOatoms.txt
#–Masses–##
mass 1 28.0855
mass 2 15.9994
#------interaction coefficients e,sigma,cutouff----------
pair_style tersoff
pair_coeff * * SiO.tersoff Si O
#initial minimization to relax surface
#minimize 1.0e-6 1.0e-4 1000 10000
#reset_timestep 0
group moving id <> 1 408
group adatom id == 408
group fixed id <> 409 965
#----initial velocity-----
timestep 0.0005
neighbor 0.7 bin
fix 1 moving neb 1.0
fix 2 fixed setforce 0.0 0.0 0.0
#------output files-------------------------------
thermo_style custom step pe etotal
thermo 1
variable u uloop 5
dump 1 moving atom 10 dump.moving.$u
dump 2 all atom 10 dump.all.$u
min_style quickmin
neb 1.0e-5 1.0e-3 1000 1000 1 coords.final Error: Illegal NEB command.
Regards,
Saketh.
configforrunwithoutOatoms.txt (28.9 KB)
coords.final (11.3 KB)
Hi all,
Input Script:
atom_style atomic
#–Masses–##
mass 1 28.0855
mass 2 15.9994
pair_style tersoff
#reset_timestep 0
timestep 0.0005
neighbor 0.7 bin
thermo 1
variable u uloop 5
min_style quickmin
Regards,
Saketh.
------------------------------------------------------------------------------ All of the data generated in your IT infrastructure is seriously valuable. Why? It contains a definitive record of application performance, security threats, fraudulent activity, and more. Splunk takes this data and makes sense of it. IT sense. And common sense. http://p.sf.net/sfu/splunk-d2dcopy2
_______________________________________________ lammps-users mailing list [email protected] https://lists.sourceforge.net/lists/listinfo/lammps-users
Hi all,
final configurations attached. Any help would be appreciated..
is your LAMMPS version up-to-date? it doesn't look like it
i don't get this error message, however, there are two
unrelated errors in your input:
1) you didn't disable atom sorting
2) you didn't tell LAMMPS to create an atom map
both are explained in the neb command documentation.
cheers,
Dr.Kohlmeyer,
Thanks for the reply. I updated the lammps version,disabled atom sorting. I get an error Cannot use neb with a single replica. I tried running the simulation with 1 node, 2 processors and 1 node, 1processor but get the same error.
Regards,
Saketh.
Dr.Kohlmeyer,
error.
yes. of course. that is what the error message tells you.
please re-read the documentation about the -partition flag.
