Dear All,
I have some problem with centroid/stress/atom
command. I used it as:
compute vis solvent centroid/stress/atom NULL
but it leads to this error:
Error: Variable formula compute vector is accessed out-of-range
My pair_style is lj/cut/tip4p/cut
My procedure:
First of all, I established a simple case, i.e simple water box and used stress/atom
command and then defined variable for six component of my isotropic stress tensor. It works.
Then, I change it to the centroid/stress/atom
command and try to define components of the stress tensor as variables. Unfortunately, I get out of range error for tthe variable of yx
component.
compute visco solvent reduce sum c_vis[4] c_vis[5] c_vis[6] &
c_vis[7] c_vis[8] c_vis[9]
variable vol equal 32768
variable pxycyl equal -(c_visco[4])/vol
variable pxzcyl equal -(c_visco[5])/vol
variable pyzcyl equal -(c_visco[6])/vol
variable pyxcyl equal -(c_visco[7])/vol
variable pzxcyl equal -(c_visco[8])/vol
variable pzycyl equal -(c_visco[9])/vol
variable p equal 20
variable s equal 1
variable d equal $p*$s
# Convert from LAMMPS real units to SI
variable kB equal 1.3806504e-23 #[J/K] Boltzmann
variable atm2Pa equal 101325.0
variable A2m equal 1.0e-10
variable fs2s equal 1.0e-15
variable convert equal ${atm2Pa}*${atm2Pa}*${fs2s}*${A2m}*${A2m}*${A2m}
fix SS solvent ave/correlate $s $p $d &
v_pxycyl v_pxzcyl v_pyzcyl v_pyxcyl v_pzxcyl v_pzycyl type auto file S0St.dat ave running
variable T equal 298
variable dt equal 1
variable scale equal ${convert}/(${kB}*$T)*${vol}*$s*${dt}
variable vxy equal trap(f_SS[3])*${scale}
variable vxz equal trap(f_SS[4])*${scale}
variable vyz equal trap(f_SS[5])*${scale}
variable vyx equal trap(f_SS[6])*${scale}
variable vzx equal trap(f_SS[7])*${scale}
variable vzy equal trap(f_SS[8])*${scale}
variable v equal (v_vxy+v_vxz+v_vyz+v_vyx+v_vzx+v_vzy)/6.00
Any comments would be appreciated,
Thanks in advance
